Ergebnis 1 bis 5 von 5
Thema: Corsa GSi Master cylinder upgrade
  1. #1
    masterx81
    Gast
    Hi to all...
    First of all, sorry for my english post, but i'am italian, and i don't know much words in german...
    I'm searching if someone, please, can say me if there is a 'straight swap' for the master cylinder found in the Corsa GSi with a bigger one...
    I'm running front + rear astra GSi disk'n'calipers, and the braking is amazing, but the pedal travel is a bit long.
    Someone can point me if there is an easy ugrade for my master cylinder?
    Thanks!!!
    P.S.: Reply in english, plaese :-)
  2. #2
    Senior VIP (Spender)
    Moderator
    Avatar von TBX
    Registriert seit
    09.05.03
    Beiträge
    4.536
    welcome to our forum!
    the master cylinders found in the corsa gsi can be used plug´n´play. you can also use the astra´s one. and if you want to go wild, try the one used in the calibra turbo :wink:
  3. #3
    masterx81
    Gast
    Thanks for the welcome! :-)
    Seem e nice community, but i know only few words in german (kolben, pluel, einpritzlage, ventil :-) )...
    I have already a corsa GSi...
    So the master cylinder of the astra will fit straight on the corsa?
    Anyone have already tryied this conversion?
    Seem a perfect match: All te Astra GSi braking parts, surely a good way!
    The problem is if the astra master cylinder will fit on the corsa servo. without too many modify...
    Thanks for the interest!!
  4. #4
    masterx81
    Gast
    So, no one have tryied this?
    Thanks!
  5. #5
    masterx81
    Gast
    Seem on e*c that some non-abs master cylinders used on the astra can be found also on the corsa. The abs one is different, but that is leaving me some hopes for a direct upgrade, stright bolt-on...
    Any other experiences?
Ähnliche Themen
  1. Borbet Gutachten gesucht ....
    Von Pitt-25 im Forum Corsa B
    Antworten: 3
    Letzter Beitrag: 09.12.11, 15:03
  2. i3401402 Heckflügel iRS - Abmessungen
    Von matzex im Forum Off-Topic
    Antworten: 1
    Letzter Beitrag: 26.09.07, 08:10
