nice work , looks great ! but how do u get the cold air to your airintake ??? and what is this behind ur handbrake ?!? :?:
das ist n druckzylinder ausm zubehör hatt das wohl anstelle vom seilzug verbaut!Zitat von TruNeo
achso , man lernt nie aus
Ist aus dem Rennsport und gibts bei Sandtler, Timms usw...
In Deutschland illegal.
Die Handbremse wirkt halt nicht mehr über Seilzüge sondern hydraulisch auf den normalen Kolben. Das bedeutet das du den ganzen Topf hinten leer machen kannst (wobei ich es dann allerdingswitzlos finde eine Bremse mit schweren Topf zu verbauen...).
Robert
ThanksZitat von TruNeo
The air of intake is absolutely cold with this system. I have tune the normal plastic grill behind the filter.
The battery take place in the trunk. It's a Twingo battery with a weight of only 7,5kg.
For the handbrake, it's a full hydraulic system with an adjustable pressure restrictor like the race system.
It's very effective in the straight corner!!! 8)8)8)8)
The use of this car is mainly on the track, not on the road.
There is also an short ratio F20 gearbox with a Quaife differential, it's realy amazing to drive with it. It's a new car!!!
hi!
do u have some pictures of the whole car? sounds interesting such a tigra "for racetrack use only"
mfg sven
was das fürn geiler blauer lack ?
Sorry but the exterior is not finish yet.Zitat von Ole
But at the end there is a "MS Design-like" body kit in fiberglass with a home made full carbon bonnet.
You can find some exterior picture on my web site: www.tigra.fr.fm
I have choosen the "Ardenblau" of the OPC model'sZitat von OsiRis2k
It's a great colour... 8)Zitat von Isma_8
Keep on working, we're waiting for more pictures...
