Corsa B with C20NE.montanatonio hat geschrieben:What's your car?
But i think that the covers are identical. So you can use the cover from the C20NE where you have other fixation points.
but what's your gearbox? F15 ?schmitty hat geschrieben:Corsa B with C20NE.montanatonio hat geschrieben:What's your car?
hum hum I will thinkschmitty hat geschrieben:No I have the F13 from the Corsa A GSI. But the problem is the same.
but what's trial is the good? lolschmitty hat geschrieben:No I have the F13 from the Corsa A GSI. But the problem is the same.
That´s my first trial:
I thought, and many people say so, that you must only work a little bit at the gearbox and it will fit perfectly. The fucking result: I had to buy a new gearbox. :twisted:montanatonio hat geschrieben:but what's trial is the good? lol
why you did not stop the hole?schmitty hat geschrieben:I thought, and many people say so, that you must only work a little bit at the gearbox and it will fit perfectly. The fucking result: I had to buy a new gearbox. :twisted:montanatonio hat geschrieben:but what's trial is the good? lol
With what? But i think that it is not a good solution to work at the gearbox. So i try to find another solution.montanatonio hat geschrieben:why you did not stop the hole?
