Upgrade Tigra 20XE
Verfasst: Do 8. Feb 2007, 13:10
von nesta
I´m looking for throttle bodies for my 20xe Tigra. I´d like to know if something mount it before and results about it.
I´d like to upgrade my motor without using turbo kits if it´s possible...
Some advises??
Thanks for all from Spain
Re: Upgrade Tigra 20XE
Verfasst: Do 8. Feb 2007, 16:35
von Tigra2.0 16V
Rear probably simplest and/or ne good basis for a stronger XE is a large exhaust system of the end from Kat.
MfG Tigra2.0 16V
Verfasst: Do 8. Feb 2007, 17:27
von Blitzcrieg
hello first of all...
sorry, but i don't understand this thing about the throttle body.. maybe my english isn't good enough to udnerstand it ?!
tigra 2.0 16v is right...
do you already have a group-a exhaust system ? ( 60 or 63,5 mm instead of 45mm stock exhaust )
If not, this could be a good point to start...
the same with the "powercap" intake manifold, which replaces the "sfi" plastik box before the the throttle...
Maybe you already have a "powercap" ?
If you don't, this is a good point to optimize the throttle-response slightly, and it also brings you 3-4 more bhp !
But many 2.0 16v tigras and corsas already have this thing after the implantation of the bigblock engine...
Another option could be a better camshaft, for better valve timings and so on...
have a lok at this, for example:
Produktansicht
mainsite is Corsa-Tigra.de
I would choose a cam with something between 268° to 275° opening time or something, and with a "hub in OT" ( the stroke of both valves at top-dead-center at the same time ) between 1,1 to 1,6 mm !
Sharper cams could ruin the all-day-practicability...
After that, a chip-tuning (ecu tuning) on the dyno could be an option, to change the engine-management for the changes done with the engine.
At the same time you could raise the fuel pressure slightly, with a new "fuel pressure regulator" which allows you to setup the pressure a little bit.
Verfasst: Do 8. Feb 2007, 21:20
von Waldbrand
Er sucht nach ner Modifikation fürn Ansaugweg, vorzugsweise ner Einzeldrosselanlage... :)
Verfasst: Fr 9. Feb 2007, 11:22
von nesta
When I swap my X14XE in C20XE I change:
- exhaust system
- light flywheels
- all the kit Mtech motorsport
- f20 (quick shift in coming)
with all this changes the motor is nearly 170hp BUT I want more...
I remember I´ve seen a Lexmaul body- injection in Corsas A with the 20XE.
Is the piece that you chage in other to the powercap.
Other opcion I think could it be using carburetors but I can´t homologate in Spain for a normal use...
Verfasst: Fr 9. Feb 2007, 17:25
von Blitzcrieg
I think it's quite difficult to fit a Lexmaul Ram Inductin Intake Manifold in a Corsa B oder Tigra with 2 litre engine...
The room under the bonnet is quite tight, so there occure problems if you want to fit a lexmaul ram to the c20xe engine...
but I'm not absolutely sure, maybe there exist some 2 litre corsas with lexmaul ram...
but in my opinion there are better things you could do...
like i said, try some new sport/street camshafts, and then a dyno-tuning for your motor-management... including slightly raised fuel pressure.
sorry, but what are carburators ? :(
Verfasst: Fr 9. Feb 2007, 18:36
von nesta
The most common and know are webber carburetors.
Look at this link:
SBD Motorsport - Budget Horsepower
Verfasst: Fr 9. Feb 2007, 18:37
von Waldbrand
Carburator sollte der Vergaser sein :)
A single-Carburator-Kit should fit into a tigra
Verfasst: Fr 9. Feb 2007, 18:43
von nesta
This is great option I think but not enough to increase at 200 hp....
I suppose I´ll have to change pulleys if I change camshafts, have I?
Thanks a lot
This is the best phoro everywhere!! (but I don´t understand deutsch and I have to translate word by word to understand "any")
Verfasst: Fr 9. Feb 2007, 19:00
von Waldbrand
By the way, where are you from?
