bonnet lifters / Problem mit Haubenliftern
Hi opel friends,got from ebay,de some bonnet lifters but not be able to fit them....any ideas how to,because tried to go with the diagram but the one bolt that holds the bonnet hits the lifter
- The Alchemist
Re: bonnet lifters / Problem mit Haubenliftern
Hi!
Old topic... there are no Plug&Play fitting lifters for the Tigra.
maybe you can try to fix it with a small piece of steelplate.
...or maybe just open a threat with "Haubenlifter" i dont thing much guys here now what "bonnet lifters" are.
mfg. Flo
mfg. Flo
I have edited the Topic title, perhaps you have more success nowThe Alchemist hat geschrieben: ...or maybe just open a threat with "Haubenlifter" i dont thing much guys here now what "bonnet lifters" are.![]()
Greetz Pic
- Black-DraGon
thats from another tread about bonntetlifter... i did this little pic-how-to to show how it works for my bonnet.
ps.
green circle, Die Schraube muss raus = you have to put out this screw
blue circle, Dämpfer festmachen = fix the new screws just here
pps.
white text, Dämpfer sorum einbauen = the shocks have to be mount like on the pic, the thick end up and the thin one down.
OK now i can see them,i ll try that.thanks again!!!
The Alchemist hat geschrieben:Hi!
mfg. Flo
Try to do it today but didnt work
i take off the bolt in the green circle but nothing
the lifter hits the first bolt ( top blue circle on the picture)
(maybe you can try to fix it with a small piece of steelplate.)
Which piece of metal should i remove?
- Black-DraGon
did u put the lifterscrew at the top of the bonnet holder???
thats wrong... it is the screw below and u have to remove the old first. after that screw the new one there and the other one at the blue circle at the fender.
u dont need to remove something u have to plug a peace of metal like a 3mm thick alu band at the bonnetscrew. thats all...
I fitted them on the lower bolt,gonna try to "space them" with 3mm or so and see ho it goes....
Thanks again
Thanks again
