20XE with F15
Anonymous
Re: 20XE with F15
I have a problem!!!
The "Clutches" of C20xe = 228 mm with 24 "teeth" BUT F15 are only 14 "teeth"!!!
How to make? There is one 220/14. Is what that assembles on C20xe???
If not, the F15 are posed well on C20xe
- blackdevil2k1
Re: 20XE with F15
just take the clutch from the engine the f15 was connectet to ... should work !
Anonymous
Re: 20XE with F15
You"re sure?????blackdevil2k1 hat geschrieben:just take the clutch from the engine the f15 was connectet to ... should work !
Corsa GSI 16v(my car) = 206mm - 14
Astra 1.6 8v = 220mm - 14
they is better the 220, not?
Anonymous
Re: 20XE with F15
If I put
of C20xe +
of astra 1.6 8v (220 - 14 )
What do you thing?
of C20xe +
of astra 1.6 8v (220 - 14 )What do you thing?
- blackdevil2k1
Re: 20XE with F15
hmm ok so you have to try if it fits ... if it fits (the astra 1.6) to the c20xe and the f15 gear .. this should be the optimal combination ... (if it worked tell me because i will do the same with the f13 on my future c20xe
the clutch from the gsi is a bit smaller but it would work too ... if you have the possebilitiy to try it with the astra clutch ... try it ...
