Wieder ein Computer Problem
superbulle718
Beitrag von superbulle718 »
Ich hab den NEC 3500AG DVD Brenner.Er brennt DVD´s problemlos aber keine CD´s.
Nero bricht ab.Neue Firmware ist drauf.(Hab auch alte probiert).
Nero´s LOG Datei:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17.07.2002 10:20:56
ahead WinASPI: File 'C:\Programme\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 13:54:32
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
Recorder: <_NEC DVD_RW ND-3500AG> Version: 2.1B - HA 1 TA 3 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PHILIPS DROM5016L >Version: 95S1 - HA 1 TA 0 - 6.6.1.4
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD2500JD-00GBB0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PHILIPS DROM5016L atapi Port 1 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-3500AG atapi Port 1 ID 1 DMA: On
CdRomPeripheral : IW0402I RCW714H 2.0B vaxscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
PHILIPS DROM5016L E: CDRom0
_NEC DVD_RW ND-3500AG F: CDRom3
IW0402I RCW714H G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047272kB)
Free physical memory: 571MB (585008kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.6.2006
Audio-CD
10:46:20 #1 CDADOC -1 File Cdadoc.cpp, Line 1456
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 04:09.41, Pause frames: 150, Filters: 0, Name: '002-bob_sinclar_-_love_generation-ministry.mp3'.
Track 02: Length: 03:01.33, Pause frames: 150, Filters: 0, Name: '003-texas_lightning_-_no_no_never-ministry.mp3'.
Track 03: Length: 05:04.46, Pause frames: 150, Filters: 0, Name: 'Blackstreet boys feat Dr Dre - No diggity.mp3'.
Track 04: Length: 04:05.00, Pause frames: 150, Filters: 0, Name: 'Puff Dady-Ill Be Missing U.mp3'.
Track 05: Length: 03:49.28, Pause frames: 150, Filters: 0, Name: 'WWE Edge's Theme Song - Alter Bridge - Metalingus.mp3'.
Track 06: Length: 06:43.46, Pause frames: 150, Filters: 0, Name: 'Special D. - Nothing I Wont Do [Extended Mix].mp3'.
Track 07: Length: 03:14.34, Pause frames: 150, Filters: 0, Name: 'Seeed - dancehall caballeros.wav'.
Track 08: Length: 03:52.38, Pause frames: 150, Filters: 0, Name: '03 - Seeed - Aufstehn ! Featuring Cee-Lo Green.mp3'.
Track 09: Length: 02:58.31, Pause frames: 150, Filters: 0, Name: '01-john_cena_and_the_trademarc-the_time_is_now.mp3'.
Track 10: Length: 04:13.40, Pause frames: 150, Filters: 0, Name: 'Bad Boys.mp3'.
Track 11: Length: 03:28.32, Pause frames: 150, Filters: 0, Name: 'Bootdelicious.mp3'.
Track 12: Length: 04:09.60, Pause frames: 150, Filters: 0, Name: 'Black Himmel.mp3'.
Track 13: Length: 03:32.16, Pause frames: 150, Filters: 0, Name: 'Maschine Eisenbass.mp3'.
Track 14: Length: 04:36.71, Pause frames: 150, Filters: 0, Name: 'Outkast Ms. Jackson.mp3'.
Total size: 57:27.66
10:46:20 #2 Text 0 File Burncd.cpp, Line 3012
Schutz vor Pufferleerlauf aktiviert
10:46:20 #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
10:46:20 #4 Text 0 File Reader.cpp, Line 124
Reader running
10:46:20 #5 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD_RW ND-3500AG running
10:46:20 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
10:46:20 #7 Text 0 File Burncd.cpp, Line 3305
Turn on Disc-At-Once, using CD-R/RW media
10:46:21 #8 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 258440 ( 57:27.65)
10:46:21 #9 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
10:46:21 #10 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: _NEC DVD_RW ND-3500AG
10:46:21 #11 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
10:46:21 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (002-bob_sinclar_-_love_generation-ministry.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 18716 (18716) = #18716/4:9.41
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18716 blocks [_NEC DVD_RW ND-3500AG]
1: TRM_AUDIO_NOPRE (003-texas_lightning_-_no_no_never-ministry.mp3)
original disc pos #0 + 13608 (13608) = #13608/3:1.33
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13608 blocks [_NEC DVD_RW ND-3500AG]
2: TRM_AUDIO_NOPRE (Blackstreet boys feat Dr Dre - No diggity.mp3)
original disc pos #0 + 22846 (22846) = #22846/5:4.46
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22846 blocks [_NEC DVD_RW ND-3500AG]
3: TRM_AUDIO_NOPRE (Puff Dady-Ill Be Missing U.mp3)
original disc pos #0 + 18375 (18375) = #18375/4:5.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18375 blocks [_NEC DVD_RW ND-3500AG]
4: TRM_AUDIO_NOPRE (WWE Edge's Theme Song - Alter Bridge - Metalingus.mp3)
original disc pos #0 + 17203 (17203) = #17203/3:49.28
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17203 blocks [_NEC DVD_RW ND-3500AG]
5: TRM_AUDIO_NOPRE (Special D. - Nothing I Wont Do [Extended Mix].mp3)
original disc pos #0 + 30271 (30271) = #30271/6:43.46
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30271 blocks [_NEC DVD_RW ND-3500AG]
6: TRM_AUDIO_NOPRE (Seeed - dancehall caballeros.wav)
original disc pos #0 + 14584 (14584) = #14584/3:14.34
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14584 blocks [_NEC DVD_RW ND-3500AG]
7: TRM_AUDIO_NOPRE (03 - Seeed - Aufstehn ! Featuring Cee-Lo Green.mp3)
original disc pos #0 + 17438 (17438) = #17438/3:52.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17438 blocks [_NEC DVD_RW ND-3500AG]
8: TRM_AUDIO_NOPRE (01-john_cena_and_the_trademarc-the_time_is_now.mp3)
original disc pos #0 + 13381 (13381) = #13381/2:58.31
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13381 blocks [_NEC DVD_RW ND-3500AG]
9: TRM_AUDIO_NOPRE (Bad Boys.mp3)
original disc pos #0 + 19015 (19015) = #19015/4:13.40
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19015 blocks [_NEC DVD_RW ND-3500AG]
10: TRM_AUDIO_NOPRE (Bootdelicious.mp3)
original disc pos #0 + 15632 (15632) = #15632/3:28.32
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15632 blocks [_NEC DVD_RW ND-3500AG]
11: TRM_AUDIO_NOPRE (Black Himmel.mp3)
original disc pos #0 + 18735 (18735) = #18735/4:9.60
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18735 blocks [_NEC DVD_RW ND-3500AG]
12: TRM_AUDIO_NOPRE (Maschine Eisenbass.mp3)
original disc pos #0 + 15916 (15916) = #15916/3:32.16
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15916 blocks [_NEC DVD_RW ND-3500AG]
13: TRM_AUDIO_NOPRE (Outkast Ms. Jackson.mp3)
original disc pos #0 + 20771 (20771) = #20771/4:36.71
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20771 blocks [_NEC DVD_RW ND-3500AG]
10:46:21 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [_NEC DVD_RW ND-3500AG] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 14:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 44372832, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 44372832 44725632 76731648, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 76731648 77084448 130818240, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 130818240 131171040 174389040, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 174389040 174741840 215203296, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 215203296 215556096 286753488, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 286753488 287106288 321407856, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 321407856 321760656 362774832, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 362774832 363127632 394599744, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 394599744 394952544 439675824, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 439675824 440028624 476795088, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 476795088 477147888 521212608, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 521212608 521565408 558999840, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 558999840 559352640 608206032, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
18716 | 2 | 0 | 0x21 | 0x00
18866 | 2 | 1 | 0x21 | 0x00
32474 | 3 | 0 | 0x21 | 0x00
32624 | 3 | 1 | 0x21 | 0x00
55470 | 4 | 0 | 0x21 | 0x00
55620 | 4 | 1 | 0x21 | 0x00
73995 | 5 | 0 | 0x21 | 0x00
74145 | 5 | 1 | 0x21 | 0x00
91348 | 6 | 0 | 0x21 | 0x00
91498 | 6 | 1 | 0x21 | 0x00
121769 | 7 | 0 | 0x21 | 0x00
121919 | 7 | 1 | 0x21 | 0x00
136503 | 8 | 0 | 0x21 | 0x00
136653 | 8 | 1 | 0x21 | 0x00
154091 | 9 | 0 | 0x21 | 0x00
154241 | 9 | 1 | 0x21 | 0x00
167622 | 10 | 0 | 0x21 | 0x00
167772 | 10 | 1 | 0x21 | 0x00
186787 | 11 | 0 | 0x21 | 0x00
186937 | 11 | 1 | 0x21 | 0x00
202569 | 12 | 0 | 0x21 | 0x00
202719 | 12 | 1 | 0x21 | 0x00
221454 | 13 | 0 | 0x21 | 0x00
221604 | 13 | 1 | 0x21 | 0x00
237520 | 14 | 0 | 0x21 | 0x00
237670 | 14 | 1 | 0x21 | 0x00
258441 | lead-out | 1 | 0x01 | 0x00
10:46:21 #14 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:46:21 #15 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:46:21 #16 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 8x (1.200 KB/s)
10:46:21 #17 SPTI -1189 File SCSIPassThrough.cpp, Line 289
F: CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1189)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 02
Buffer x03016600: Len x4000
10:46:21 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:46:21 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #18866
10:46:21 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #32624
10:46:21 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #55620
10:46:21 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #74145
10:46:21 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #91498
10:46:21 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #121919
10:46:21 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #136653
10:46:21 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #154241
10:46:21 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #167772
10:46:21 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #186937
10:46:21 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #202719
10:46:21 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #221604
10:46:21 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #237670
10:46:21 #32 Text 0 File Mmc.cpp, Line 17161
StartDAO : CD-Text - On
10:46:21 #33 Text 0 File Mmc.cpp, Line 21840
Set BUFE: Buffer underrun protection -> ON
10:46:21 #34 Text 0 File Mmc.cpp, Line 17394
CueData, Len=240
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 04 0b 29
21 02 01 00 00 04 0d 29
21 03 00 00 00 07 0e 4a
21 03 01 00 00 07 10 4a
21 04 00 00 00 0c 15 2d
21 04 01 00 00 0c 17 2d
21 05 00 00 00 10 1c 2d
21 05 01 00 00 10 1e 2d
21 06 00 00 00 14 13 49
21 06 01 00 00 14 15 49
21 07 00 00 00 1b 05 2c
21 07 01 00 00 1b 07 2c
21 08 00 00 00 1e 16 03
21 08 01 00 00 1e 18 03
21 09 00 00 00 22 10 29
21 09 01 00 00 22 12 29
21 0a 00 00 00 25 10 48
21 0a 01 00 00 25 12 48
21 0b 00 00 00 29 20 25
21 0b 01 00 00 29 22 25
21 0c 00 00 00 2d 02 45
21 0c 01 00 00 2d 04 45
21 0d 00 00 00 31 0e 36
21 0d 01 00 00 31 10 36
21 0e 00 00 00 34 30 46
21 0e 01 00 00 34 32 46
01 aa 01 01 00 39 1b 42
10:46:42 #35 SPTI -1135 File SCSIPassThrough.cpp, Line 289
F: CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 FF FF DD 51 00 02 AA 00 00 00
Sense Area: 0x70 00 03 FF FF DC 3D 0A 00 00 00 00 0C
Buffer x036d0000: Len xffc0
0x20 10 24 20 03 06 10 20 1D 06 21 25 08 05 11 32
0x18 16 11 25 1B 15 1F 12 20 10 24 21 03 36 05 32
0x18 30 01 02 18 16 10 00 1B 26 3C 20 18 1B 36 04
10:46:42 #36 CDR -1135 File Writer.cpp, Line 311
Write error
F: _NEC DVD_RW ND-3500AG
10:46:42 #37 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
10:46:42 #38 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
10:46:42 #39 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 8x (1.200 KB/s)
10:46:42 #40 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
10:46:42 #41 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.08.2005 04:00:00
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 17.07.2002 09:53:02
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Bitte brauche hilfe
thrilex
Re: Wieder ein Computer Problem
Beitrag von thrilex »
hmm
hast du SP 1 oder SP2 drauf?
welche medien benutzt du ?
also ich hatte mal stress mit platinum cds dann hab ich andere von verbatin genutzt und die klappten super...
VeNoM
Beitrag von VeNoM »
Ich benutze meistens eigentlich die aldi Tevion, die Spindeln wurden mir zublöd jedesmal hüllen zu kaufen ^^ die kann ich mit meinem NEC eigentlich problemlo brennen, versuch einfach mal ne andere Rohling marke kann schon sein das es sich mal bei einer etwas zwickt
thrilex
also verbatin / tevion und hmmm TDK kann ich empfehlen mit dennen hatte ich noch niee probleme
superbulle718
Ich hab das SP2.Habe Rohlinge von Netto.Konnte damit aber Monate lang problemlos brennen.Die DVD-Rs nehme ich auch von der Marke
thrilex
hmm von einem tag auf den anderen gings nicht mehr?
hhmm haste irgent einen neuen IDE treiber installiert?
oder vieleicht updates gemacht?
oder nero vieleicht neuinstallieert?
oder sowas?
hmmm
superbulle718
Nur halt die Windows Updates ansonsten eigentlich nix.
Thundang
Beitrag von Thundang »
ich könnt ja jetz was sagen, aber mach nie von microsoft nen update wart lieber bis nen neues sp raus is und du darüber auch berichte gelesen hast.
mein tipp falls es geht reinstalliere das update sonst hilft nur neuinstallation mit sp2 so wie du es vorher hattest
NLORD
Beitrag von NLORD »
Hallo, du hast geschrieben, dass Nero Probleme macht, aber hast du schonmal eine andere Brennsoftware ausprobiert? Es kann durchaus an Nero liegen.
Gibt es noch weitere Software auf deinem Rechner, die Nero beeinflussen könnten(Alcohol, ...)?
Zudem, wenn du die Möglichkeits hast den Brenner in einen anderen Rechner zu bauen und dort zu versuchen(könnten oftmals irgendwelche Einstellungen, Treiber, etc. sich gegenseitig austricksen), dann mach das mal.
Wenn es da immer noch nicht funktioniert, kann es auch ein Hardwarefehler sein!
thrilex
also hmm nero neuinstallieren und testen wens nciht geht
anderen programm testen wens nicht geht
mit garantiebeleg zum händler und brenner reklamienen :D :D :D
