CDA in Tigra 20XE??
Alles über den Tigra
Moderatoren: FTBerlin, Iceman
nesta
CDA in Tigra 20XE??
Beitrag von nesta »
I´d like to know your opinion about mounting CDA Air Admision Box System in a Tigra 20XE.
What about Dbilas Flowmaster system??
Thanks
ch_wagner
Re: CDA in Tigra 20XE??
Beitrag von ch_wagner »
Fireproof
Beitrag von Fireproof »
@ch
das is die airbox
ch_wagner
nesta
Beitrag von nesta »
Green Air filter is bad.
I had mounted CDA in the original X14XE and it was ok and I want to know if it´s good in the 20XE too.
Nobody knows??
Fummy
Beitrag von Fummy »
Yes, the CDA Box are great on the C20XE, the best what you can make! :thumsup:
nesta
Beitrag von nesta »
Fummy hat geschrieben:Yes, the CDA Box are great on the C20XE, the best what you can make! :thumsup:
Thanks fummy!!
Your Tigra is really good
