X12XE Idling runs a corner of ignition.
Vadik
Beitrag von Vadik »
Hi from Russia. A problem I can not already solve the whole year. The corner of ignition should be 6 degrees. But on my motor changes idling from-5 up to +25 degrees. Idling non-uniform.
Re: X12XE Idling runs a corner of ignition.
you can´t set the corner of ignition yourself at a x12xe. the motor-control-unit does it. the non-uniform idling can be caused by the air-mass-sensor sitting in the airaintakehose just between the airfilterbox and the engine.
Vadik
Beitrag von Vadik »
I understand, but I have disconnected all sensors except for
impulse sensor - crankshaft and a corner all equally jumps. Once there was a problem with Throttle valve positioner and the lamp has lighted up check up the motor. And so during this moment the corner of ignition did not jump. In Russia to me who cannot help. Very rare motor.
